ONTAP Discussions
FilerView not accessible on DataOntap 8.1.R3 7mode on fas2040 ( IBM N3400)
gokhancakir
Hi everyone,
I recently upgrade our filer from dataontap 7.3.6 to 8.1.R3. after upgrade i checked i can't access FilerView. I am not sure can i access before upgrade.
when i list under http folder it's looking empty. i downloaded again ontap 8.1.R3 but nothing changed.
here is outputs;
n3400-b*> ls /vol/vol0/home/http
n3400-b*>
n3400-b*> options http
httpd.access                 legacy
httpd.admin.access           legacy
httpd.admin.enable           on
httpd.admin.hostsequiv.enable off
httpd.admin.max_connections  512
httpd.admin.ssl.enable       on
httpd.admin.top-page.authentication on
httpd.autoindex.enable       off
httpd.bypass_traverse_checking off
httpd.enable                 off
httpd.ipv6.enable            off
httpd.log.format             common     (value might be overwritten in takeover)
httpd.method.trace.enable    off
httpd.rootdir                /vol/vol0/home/http
httpd.timeout                300        (value might be overwritten in takeover)
httpd.timewait.enable        off        (value might be overwritten in takeover)
Thanks for help..
1 ACCEPTED SOLUTION
cedric_renauld
Hi, Sorry but until the 8.1 the FilerView is deprecated,
you can download the onCommand System manager to manager your NSerie
4 REPLIES 4
cedric_renauld
gokhancakir
Thanks Cedric, I already using ssh and system manager for manage my filer. but some settings ( like nfs permission and config) Filerview is really helpful.
we have to wait thanks again..
arunchak
Right, but system manager has easier work-flows and  much better manageability. Filer view is out dated. To add to it, you can manage multiple (c-mode as well as 7-mode) systems through system manager.
esutiawan
Yeah, system manager much more capabilities than filler view, but on client must be installation the program. different with filer view, after installation, customer just point ip address to the web browser to manage it, little easy...:). Some time system manager very slow too  . better using command line for geek user...
