ONTAP Discussions
Maximum number of HA pairs that are supported when using a SAN cluster
Zulhadi
Hi. Just for asking. Anyone here can share info with me what is maximum number of HA pairs that are supported when using a SAN cluster in ONTAP 9.1? I try looking for this info but still not found. Thank
regards,
Zulhadi
1 ACCEPTED SOLUTION
Damien_Queen
If you have 2240 systems, max number of nodes in SAN cluster is 4 ( 2x HA)
If you have 2500 or 3200 systems, max number of nodes in SAN cluster would be 8 nodes (4x HA)
Any other models - 12 nodes (6x HA)
If you have mix of systems, the smallest system will determine max number of nodes in your cluster.
2 REPLIES 2
Damien_Queen
Damien_Queen
The easiest way to find the answer to your question by yourself is to use http://hwu.netapp.com
