ONTAP Discussions
Move LUN to another volume
anders_hansen
Hi
Is it possible to move a LUN to another volume on the same filer?
I am running ontap 8.0.2.
Thank you in advance
1 ACCEPTED SOLUTION
radek_kubka
I would add one step:
4a: Boot up the host & check everything works
& then delete old LUN
With NDMP you need to shut down your host first & then copy the LUN.
4 REPLIES 4
radek_kubka
Hi,
That depends what do you mean by 'move' - disruptively, or non-disruptively?
For the former, you can use a bunch of methods, e.g. SnapMirror from source volume to a target volume (if it's empty), use NDMP copy, etc.
For the latter, you may consider DataMotion:
http://now.netapp.com/NOW/knowledge/docs/ontap/rel802/html/ontap/rnote/GUID-BF933A3F-AC0E-4D87-B57D-C2A7BC71D926.html
But the source & destination aggregate must be different.
Regards,
Radek
anders_hansen
I would prefer non-disruptive.
With snapmirror it would be:
1: snapmirror the LUN from one volume to antoher
2: Shutdown the host connected to the LUn
3: Sync with snapmirror
4: Move initiatorgroup from the old LUN to the new
5: Delete old_lun
Is the same possible with NDMP-copy?
Datamotion only moves volumes, not individual LUN's.
radek_kubka
KENT_LANGE
Can you elaborate on the commands to perform this action. I am very new to the Netapp and my previous method of moving LUNs is using a Windows based Sync App.
