ONTAP Discussions
OnTap 8.3.2 System Manager Not Working
MarkTayler
I have a cluster running OnTap 8.3.2
The cluster and node management network interfaces are active
and I can ssh to them.
The web services are up and running
Cluster::> sys ser web show
  (system services web show)
 External Web Services: true
                Status: online
    HTTP Protocol Port: 80
   HTTPs Protocol Port: 443
         TLSv1 Enabled: true
         SSLv3 Enabled: false
SSL FIPS 140-2 Enabled: false
I am using I.E. 8
When I attempt to access the filer via the GUI (using https),
using the cluster IP I get the security certificate error,
click continue to this website
The URL is https://nnn.nnn.nnn.nnn/sysmgr/SysMgr.html
The screen stays white and I am not prompted for the credentials.
Any ideas ?
Thanks in Advance
1 ACCEPTED SOLUTION
ekashpureff
Mark -
IE 8 is not supported.
See the supported browsers here:
https://library.netapp.com/ecmdocs/ECMLP2348067/html/GUID-74BC2023-C464-4958-88E0-B758B6003F9B.html
I hope this response has been helpful to you.
At your service,
Eugene E. Kashpureff, Sr.
Independent NetApp Consultant http://www.linkedin.com/in/eugenekashpureff
Senior NetApp Instructor, FastLane US http://www.fastlaneus.com/
(P.S. I appreciate 'kudos' on any helpful posts.)
3 REPLIES 3
ekashpureff
Mark -
At your service,
MarkTayler
That Worked, upgraded to Firefox 50.
Thanks,
Mark
StephaneOng
Hello,
Just a update to that ticket to give another solution.
I had exactly the same problem (404 page not found) after i did a downgrade from ONTAP 9.1P2 to ONTAP 8.3.2P9.
I notice that service name "sysmgr" was not enable and i simply run the following command : "
services web modify -name sysmgr -enabled true
Hope it will help someone one day.
Cheers
Stéphane
