ONTAP Discussions
Problems with an _ in the DNS name with OnTap 9.3
Trubida
I have a AFF system running OnTap 9.3P1 and am seeing a strange issue.  If we have a DNS entry for the cluster mgmt interface ,that contains an "_" character, I recieve the following error when trying to load the System Manager interface.
Bad Request
Your browser sent a request that this server could not understand.
Additionally, a 400 Bad Request error was encountered while trying to use an ErrorDocument to handle the request.
If I go to the IP address or a DNS entry that doesn't contain an _ I can logon as normal.
Is anyone else seeing this?
1 ACCEPTED SOLUTION
EWILTS_SAS
Underscores are not valid in DNS hostname entries.
The authoritative answer is in http://www.ietf.org/rfc/rfc952.txt
1. A "name" (Net, Host, Gateway, or Domain name) is a text string up
   to 24 characters drawn from the alphabet (A-Z), digits (0-9), minus
   sign (-), and period (.).
4 REPLIES 4
EWILTS_SAS
CSiegle
Trubida - Were you able to confirm this?
AlexDawson
Underscores are never ok in hostnames. Please change your DNS entries and it should all work fine.
zamkovoy8
https://mysupport.netapp.com/NOW/cgi-bin/bugrellist?bugno=1139424
agree, it was never a good idea.. i guess that escaped NetApp guys not just once .. ONTAP Cloud default SVM name is created using svm_  prefix .. even today.
