ONTAP Discussions
Reinstall of OnTap required?
Willybobs27
I have a 2240 with 24 SAS drives, 12 assigned to each controller default raid group size
A new DS4243 shelf is being added, with SATA drives
The customer now wants the 24 SAS drives in one aggr assigned to one controller and 24 SATA drives in one aggr assigned to the other.
Can I acheive this without a complete reinstall of OnTap? If so how.
If an OnTap reinstall is required how do I do that?
2 REPLIES 2
ralfaro01zero
Hi Willy,
Do you have a SnapMirror license? If so, you can SnapMirror the root volume from one aggregate to the other, destroy the decommissioned aggregate, add the disks from the destroyed aggregate to the desired aggregate, create the new aggregate with the new disks, then SnapMirror the root volume to the new aggregate.
Cheers.
jbradley
Hi,
Logically I would think this could be achieved by performing the following tasks:
1.  Migrate all data from the aggregate you wish to offline/destroy.
2.  Connect the new DS4243 w/ 1TB drives and create a new aggregate on the controller you wish to be dedicated to SATA.
3.  Perform an NDMP copy of the root vol off of the aggregate with SAS onto the new aggregate with SATA and bring it online. Please refer to the link (https://communities.netapp.com/thread/14353)
4. Offline the empty SAS aggregate and destroy it.  Zero all of these disks and remove ownership from the original filer to the new filer and add these disks to the existing SAS aggregate on the other controller. (Would recommend looking up best practices on adding disks/raid groups to existing online/active aggregates).
***This is not guaranteed to work for you in your scenario however I performed this successfully in my lab with an older system running 8.0.1.  I would recommend scoping out this project and doing your due-diligence in regards to planning, homework, etc.  Also reaching out to other resources never hurts!***
