ONTAP Discussions
Unable to connect to filer using connect-NcController (Netapp 7.3.7p1)
Krissh_9
Hi, I am new to Netapp. When I use "  Connect -NController X.X.X.X " with credentials, I am getting this error. can someone help me with this?
Connect-NcController : Not a clustered Data ONTAP controller
At line:1 char:1
+ Connect-NcController 192.168.2.16 -Http
    + CategoryInfo          : InvalidResult: (192.168.2.16:NcController) [Connect-NcController], InvalidOperationExc
   tion
    + FullyQualifiedErrorId : Not a clustered Data ONTAP controller,DataONTAP.C.PowerShell.SDK.ConnectNcController
Thanks.
1 ACCEPTED SOLUTION
JGPSHNTAP
Are you trying to connect to cdot or 7-mode
if 7-mode you need connect-nacontroller
6 REPLIES 6
JGPSHNTAP
Krissh_9
Hi,
I am not sure about cdotor 7-mode but the device is not clustered.
When I use Connect-NaconnectorI am getting this:
PS C:\Windows\system32> Connect-NaController 192.168.2.16
Connect-NaController : Failed to load ntapadmin64 DLL
At line:1 char:1
+ Connect-NaController 192.168.2.16
    + CategoryInfo          : InvalidResult: (192.168.2.16:NaController) [Connect-NaController], Exception
    + FullyQualifiedErrorId : RpcConnectionFailed,DataONTAP.PowerShell.SDK.ConnectNaController
Thanks
Krissh_9
Hi,
At line:1 char:1
Thanks
sinhaa
@Krissh_9 @JGPSHNTAP
What is the windows version you are using? I'm facing the same issue and my windws is win server 2016.
Does anyone know how to get out of it?
sinhaa
If this post resolved your issue, help others by selecting ACCEPT AS SOLUTION or adding a KUDO.
Pumpith
Please try use command
$connection = Connect-NaController $filername -credential ${Credential}
buddystorage
Netapp cdot 9.8 we have used powershell to connect i got below error.Please help me.
PS C:\Program Files (x86)\PowerShell> Connect-NaController 10.178.16.27 -credential {admin}
Connect-NaController : The term 'Connect-NaController' is not recognized as the name of a cmdlet, function, script file, or operable program. Check the spelling of the name, or if a path was
included, verify that the path is correct and try again.
At line:1 char:1
+ Connect-NaController 10.178.16.27 -credential {admin}
+ CategoryInfo : ObjectNotFound: (Connect-NaController:String) [], CommandNotFoundException
+ FullyQualifiedErrorId : CommandNotFoundException
