ONTAP Discussions
vFiler and Snapmirror compression
Willybobs27
Can I use snapmirror compression with a vFiler Destination?
I've tried this on simulators and cannot seem to get this working.
Also vFilers don't have a snapmirror.conf file?
1 ACCEPTED SOLUTION
scottgelb
a Volume in a vFiler can be mirrored from vfiler0 or from the vfiler itself.  In the case of data motion, dr and migrate functions it requires vfiler0...but if a mirror outside of that you can go either way.  If inside the vfiler then there is a snapmirror.conf on the target vfiler.  Turning on compression in the vfiler snapmirror.conf should work the same... one caveat for any mirror compression is that in addition to compression=yes you also need to have a source connection setup...even if not using 2 ip addresses you need a multi or failover port defined... if one ip only then define with a single port...
source_connection = multi (ipsrc1,ipdest1) (ipsrc2,ipdest2)               # you could define this with a single ip pair instead of 2 if you only have 1... required for compression
source_connection:srcvol destfas:destvol compression=enable - 0-59/15 * * *
3 REPLIES 3
paul_wolf
Hmm, really good question. I've always used the parent controller for my SnapMirror sessions and never the vFiler in 7-mode.
scottgelb
Willybobs27
I've managed to get this working in the simulators. The bit that was throwing me was the lack of the snapmirror.conf file. I just manually created this and it all burst into life.
