Data Protection
SnapCenter Scheduled task not running - no errors in logs?
bobalon
Hi there
Have a very strange issue using Snapcenter v4.4 to backup MS SQL databases. We have 4 servers with 2 each in 2 resource groups each with 3 policies applied with schedules.
The schedules are set to run from the MS SQL agent via the snapCenter GUI and I can see them in MS SQL on each server.
On 1 server 1 of the jobs works fine and the other 2 never seem to run, on the other server 2 jobs run fine as per schedule and the 3rd never seems to run.
There are no errors in the logs, or joblauncherlog
if I execute the agent jobs from MS SQL manually they run fine.
Seems strange that all 6 jobs have been created automatically via snapcenter using the same creds etc and yet 3 do not run.
Have I hit a known issue/bug and if so has anyone found a work around for this?
Thank you
1 REPLY 1
