FAS and V-Series Storage Systems Discussions
Highlighted
4243 shows "?" for shelf and bay
Good day!  I am working though a reconfigure of a FAS 2040 + DS4243 (you may recognize this as I was posting other questions under another user ID recently).  I have just finished adding 1TB drives into the DS 4243 and they are all functioning properly in RAID-DP from the shelf.  I haven't been able to clear our the amber warning lights yet although all drives are alive and hosting CIFS data (just test data for now)  All drives "0d" are from the 4243 shelf and "0c" are the internal drives from the 2040.  Whats the best way to figure this one out?
Aggregate aggr0 (online, raid4) (block checksums)
  Plex /aggr0/plex0 (online, normal, active)
    RAID group /aggr0/plex0/rg0 (normal)
      RAID Disk Device          HA  SHELF BAY CHAN Pool Type  RPM  Used (MB/blks)    Phys (MB/blks)
      parity    0c.00.1         0c    0   1   SA:A   -  SATA  7200 423111/866531584  423946/868242816
      data      0c.00.2         0c    0   2   SA:A   -  SATA  7200 423111/866531584  423946/868242816
Aggregate aggr1 (online, raid_dp) (block checksums)
  Plex /aggr1/plex0 (online, normal, active)
    RAID group /aggr1/plex0/rg0 (normal)
      dparity   0d.01.9         0d    ?   ?   SA:B   -  SATA  7200 847555/1735794176 847884/1736466816
      parity    0d.01.8         0d    ?   ?   SA:B   -  SATA  7200 847555/1735794176 847884/1736466816
      data      0d.01.10        0d    ?   ?   SA:B   -  SATA  7200 847555/1735794176 847884/1736466816
      data      0d.01.7         0d    ?   ?   SA:B   -  SATA  7200 847555/1735794176 847884/1736466816
      data      0d.01.6         0d    ?   ?   SA:B   -  SATA  7200 847555/1735794176 847884/1736466816
      data      0d.01.5         0d    ?   ?   SA:B   -  SATA  7200 847555/1735794176 847884/1736466816
      data      0d.01.4         0d    ?   ?   SA:B   -  SATA  7200 847555/1735794176 847884/1736466816
      data      0d.01.3         0d    ?   ?   SA:B   -  SATA  7200 847555/1735794176 847884/1736466816
      data      0d.01.2         0d    ?   ?   SA:B   -  SATA  7200 847555/1735794176 847884/1736466816
      data      0d.01.1         0d    ?   ?   SA:B   -  SATA  7200 847555/1735794176 847884/1736466816
      data      0d.01.0         0d    ?   ?   SA:B   -  SATA  7200 847555/1735794176 847884/1736466816
Spare disks
Spare disks for block or zoned checksum traditional volumes or aggregates
spare           0c.00.0         0c    0   0   SA:A   -  SATA  7200 423111/866531584  423946/868242816 (not zeroed)
spare           0d.01.11        0d    ?   ?   SA:B   -  SATA  7200 847555/1735794176 847884/1736466816 (not zeroed)
Partner disks
partner         0c.00.10        0c    0   10  SA:A   -  SATA  7200 0/0               423946/868242816
partner         0c.00.9         0c    0   9   SA:A   -  SATA  7200 0/0               423946/868242816
partner         0c.00.11        0c    0   11  SA:A   -  SATA  7200 0/0               423946/868242816
sv-storage-1a> Thu May 15 12:00:00 CDT [sv-storage-1a: kern.uptime.filer:info]:  12:00pm up  1:05 0 NFS ops, 36 CIF S ops, 0 HTTP ops, 0 FCP ops, 0 iSCSI ops
1 REPLY 1
Re: 4243 shows "?" for shelf and bay
First you should zero your spares..
(disk zero spares)
Try led_off and see if that will hold the service light off
Try the new BETA Support Site!
Beta Support Site
Forums
