Thre are 3 disk failures, please advise.
Please find the errors below:
filer02: monitor.shutdown.brokenDisk.pending:warning]: the parity disk and a data disk in RAID group /aggr1/plex0/rg0 are broken. Halting system in 15 hours.
filer02: raid.config.filesystem.disk.failed:error]: File system Disk /aggr1/plex0/rg0/0a.32 Shelf 2 Bay 0 [NETAPP X269_HJUPI01TSSX NA01] S/N [N00V103L] failed.
[filer02: disk.failmsg:error]: Disk 0a.32 (N00V103L): message received, maintenance center recommended.
Fri Jul 7 20:42:36 BNT [filer02: raid.disk.unload.done:info]: Unload of Disk 0a.32 Shelf 2 Bay 0 [NETAPP X269_HJUPI01TSSX NA01] S/N [N00V103L] has completed successfully
Fri Jul 7 20:42:46 BNT [filer02/filer01: iscsi.service.startup:info]: iSCSI service startup
Fri Jul 7 20:42:47 BNT [filer02/filer01: raid.fdr.failed.ok:info]: Disk 0a.35 Shelf 2 Bay 3 [NETAPP X269_HJUPI01TSSX NA01] S/N [N00WLAUL] successfully deleted from spare pool
Fri Jul 7 20:42:47 BNT [filer02/filer01: raid.fdr.failed.ok:info]: Disk 0a.32 Shelf 2 Bay 0 [NETAPP X269_HJUPI01TSSX NA01] S/N [N00V103L] successfully deleted from spare pool
Fri Jul 7 20:42:47 BNT [filer02/filer01: raid.fdr.failed.ok:info]: Disk 0a.33 Shelf 2 Bay 1 [NETAPP X269_HJUPI01TSSX NA01] S/N [N00W75PL] successfully deleted from spare pool
Fri Jul 7 20:42:47 BNT [filer02/filer01: raid.fdr.failed.ok:info]: Disk 0a.40 Shelf 2 Bay 8 [NETAPP X269_HJUPI01TSSX NA01] S/N [N00V0W8L] successfully deleted from spare pool
