Hi,
We have a FAS2240-2 with 24 x 900GB SAS drives running ONTAP 8.1.1P4 7-Mode.
We would like to convert it to a DS2246 disk shelf and connect it to a FAS2552 with 24 x 900GB SAS drives running CDOT 8.3.2 (no external disk shelves).
I've been reading the documentation on converting a 2240 to a disk shelf and the process seems overly complex.
Is it not possible to:
- Boot the 2240 into maintenance mode and zero the disks.
- Power off the 2240 and replace the controllers with IOM6 modules.
- Power on the (old) 2240 and change the shelf id.
- Connect it to the FAS2552 filer?
We did something similar recently when we (non-disruptively) moved 3 x 4243 disk shelves from a FAS3210 running 8.1.1P1 7-Mode to a FAS8020 with 4 existing 4243 disk shelves running CDOT 8.3.1P1.
All we had to do was zero the disks on the 3210 before cabling the shelves to the new system.
Thanks.
