FAS and V-Series Storage Systems Discussions
DS4243 and V-Series
It seems that the new shelf DS4243 will be supported on V-Series.
Is it supported on single as well as on clustered systems? Also is it supported on V-Series Fabric Metrocluster (non-mirrored)?
Thanks
Christoph
2 REPLIES 2
Re: DS4243 and V-Series
Hi Chris,
Yes, single and clustered heads are supported. Metrocluster with Native disks is not supported.
Thanks!
Dan's answer is of course correct, although the appropriate terminology for an dual-controller system is an HA pair or HA system; cluster is the term for multi-node GX or Data ONTAP 8 clustered systems.
The reason the DS4243 shelf cannot be used in either stretch or fabric MetroCluster configurations has to do with SAS specification limits on cable lengths: the current maximum supported passive SAS cable is 5m. SAS use copper cables; there is no physical interface for fibre and switches.
Skip Shapiro
Cloud Volumes ONTAP
Review Banner
All Community Forums
