ONTAP Hardware
Error code=ADMIN_OLD_VALUE_CHANGED
sameerrane
I am using NetCache Appliance, Version NetApp Release 6.0.3.
I am facing an issue in 'allow url-prefix' ACL. Whenever i am trying to add a URL getting below error,
An Error Occurred On This Page:
[code=ADMIN_OLD_VALUE_CHANGED] The values on the page you were trying to commit have been changed while you were looking at them. This page contains the current values.
Please help in resolving this error.
Thanks in Advance
Sameer
2 REPLIES 2
chrisponroy223
We are using NetCache Appliance, Version NetApp Release 6.0.2
We observed the same error code (see below) when we are trying to add a new forwarding rule
Did you receive a response to resolve this error ?
Thanks for your collaboration
Chris
sameerrane
Hi Chris
I had connected to NetApp box using Telnet and then managed to remove the
Last ACL line through Command Line Interface. I have used below command to
remove ACL
delete config.http.acl 'allow url-prefix "
http://service.velaro.com/visitor/PrechatSurvey.aspx?SurveyID=10780&sid=gjfcwumfjv5pliny4objxpf3&siteid=4470&showwhen=inqueue
After deleting, I have tested adding a new ACL and removing an existing
ACL. It worked fine.
The error was due to the special characters used in the URL which changed
some admin values. So from Net Apps Logs, you can find out the last wrong
entry you added into the NetApp.
Thanks and Regards
Sameer Rane
Colgate-Palmolive Company
Global SSO - Mumbai, India
Direct Line : 91-22-6709-2228
Chris ponroy <community@netapp.com>
To:
Sameer Rane/INDBO/AP/COLPAL@COLPAL
Date:
03/18/2009 03:03 AM
Subject:
New message: "Error
code=ADMIN_OLD_VALUE_CHANGED"
Sameer Rane,
A new message was posted in the thread "Error
code=ADMIN_OLD_VALUE_CHANGED":
http://communities.netapp.com/message/8206#8206
Author : Chris ponroy
Profile : http://communities.netapp.com/people/chrisponroy223
Message:
