ONTAP Hardware
FAS 8040 frequent high CPU
marcinmf
Hello we are running Ontap 9.2
We are monitoring hardware performance and regularly during the day especially in afternoon hours we see spikes in CPU usage up to 90%
Is there a way to discover what the cause is?
We were running some commands
priv set diag;statit -b
priv set diag;statit –e
sysstat -x
Attached are some results and comparison of 2 different results.
The spikes are for few seconds and goes down to 20%.
Thank you,
Martin
ANY  AVG  CPU0 CPU1 CPU2 CPU3 CPU4 CPU5 CPU6 CPU7
 44%  14%    9%   9%  10%   9%   7%   9%  30%  29%
 65%  20%   12%  11%  12%  13%   8%  11%  45%  45%
 43%  12%    7%   7%   7%   7%   5%   6%  29%  29%
 42%  11%    6%   5%   6%   6%   4%   5%  28%  28%
100%  73%   67%  72%  65%  69%  60%  67%  91%  91%
100%  71%   64%  67%  61%  63%  55%  75%  90%  90%
 99%  76%   71%  70%  69%  67%  63%  90%  89%  89%
100%  95%   94%  94%  94%  94%  94%  98%  98%  98%
 97%  63%   55%  55%  54%  53%  48%  81%  82%  81%
100%  56%   46%  42%  43%  37%  34%  79%  81%  82%
 87%  45%   33%  27%  41%  36%  37%  62%  61%  59%
 35%  12%    5%   5%  15%  15%  15%  14%  14%  14%
 30%  10%    3%   3%  12%  12%  12%  12%  11%  11%
 29%  10%    3%   3%  11%  12%  12%  12%  11%  12%
 38%  13%    5%   4%  16%  16%  16%  16%  16%  16%
 40%  14%    8%   6%  13%  14%  13%  13%  22%  21%
 73%  29%   22%  20%  20%  21%  14%  24%  55%  54%
 73%  26%   19%  23%  25%  20%  14%  19%  43%  43%
1 ACCEPTED SOLUTION
paul_stejskal
Not enough detail here to really accurately fully diagnose. I would recommend opening a support case so we can pull performance archives.
3 REPLIES 3
kahuna
none of the 3 files attached is showing high CPU
marcinmf
Please take a look on attached chart. The CPU spikes keep repeating over the time.
Martin
paul_stejskal
