FAS and V-Series Storage Systems Discussions
Highlighted
FAS2240-4 Configuration Question
I have two FAS 2240-4 NetApp's that I configured the same.  Both with 10 disks assigned to each controller with 2 spare disks per each controller.  I now realize that the second 2240-4 should have been setup to have 18 disk assigned with 2 spares to controller 1 and 3 drives to controller 2 with one spare.
I am not using this second system but I need to change to this configuration.  What steps do I need to take to destroy the second aggregate and move the drives to the first controller?
Thanks
3 REPLIES 3
Highlighted
Re: FAS2240-4 Configuration Question
Hello,
You need to reboot your second controller, and go to maintenance mode to re-install your base system.
You could also create a new aggregate with the 2 spare drives and move the vol0/root volume to it, but it is harder to perform.
On your second HA controller :
- disable HA with cf disable
- reboot
- go to maintenance mode using CTRL-C
- reinstall the system (using the right option which is "install a new system" I guess, I'm not completely sure.
Regards,
Jean-Christophe
Highlighted
Move one spare disk to controller 2 (so you'll have 1 spare on ctrl 1 and 3 on ctrl2)
Create a new raid4 aggregate on ctrl2 using 2 spare disks
Move the root vol to this new raid4 aggregate (this requires a reboot of ctrl2)
Destroy the original aggregate on ctrl2 (assuming you don't have any important data left in it - you did say it's unused)
Reassign the freed disks to ctrl1, leaving yourself 2 spares in ctrl2 (one as a real spare, and the second one to convert your raid4 aggr to raid-dp)
Hope that helps.
Highlighted
Thanks for the information I will need to try this next week.
On Mon, Apr 28, 2014 at 9:44 AM, resqme914 <
Try the NEW Knowledgebase!
NetApp KB Site
Forums
