FAS and V-Series Storage Systems Discussions
Highlighted
FAS2554 upgrade to ONTAP 9.1 - Is recommended?
Hi,
my FAS2554 (20x4TB+4x400SSD) is running 8.3.2P12 and works fine (I'm using only NFS as protocol).
Now I would like upgrade to 9.1P19 as suggested by Upgrade Advisor because for 8.3 NetApp don't provide anymore support.
Since FAS2554 was born with 8.3 so, is safe and recommended upgrade to 9.1?
Should I expect a drop in performance?
Thanks
6 REPLIES 6
Highlighted
Re: FAS2554 upgrade to ONTAP 9.1 - Is recommended?
We have FAS25xx series controllers running 9.5P4 with no issue, and upgrades have made them faster, not slower (when using the same features/workloads).
Highlighted
I'd go as high as possible. There are a few things that will make 9.3+ better. Ideally if you can go to 9.5Platest that would be the best.
Highlighted
Thanks Paul,
I will follow the upgrade path provided from Upgrade Advisor, so 8.3 -> 9.1, 9.1 -> 9.x and so on.
But ONTAP 9.5 can works fine with FAS2554 that have less RAM than 2750 (36GB vs 64GB)?
Highlighted
Yes. I've seen several filers on 9.5 on 2500s.
Highlighted
One gotcha we just identified. A SSL cert expired on the 6th within ONTAP, so if you go past 9.1 to 9.3 then 9.5, you will encounter an error. See https://kb.netapp.com/app/answers/answer_view/a_id/1089462 for more information.
If you encounter this problem this is well documented and Support can help on a case when doing the upgrade, otherwise patch releases for 9.3 and 9.5 will be out in a few days it seems.
Highlighted
Hi,
I have done the upgrade via CLI and all works fine.
Only one thing need to fix, about every 5 minutes in the Events Log I found this debug messages:
acp.command.connect: Could not establish connection with 192.168.2.145.
and from console:
cluster2::> storage shelf acp module show
Node               Module Name        State
cluster2-node01    1.0.B              connection-error
                   1.0.A              connection-error
cluster2-node02    1.0.B              connection-error
4 entries were displayed.
cluster2::> storage shelf acp show
Node                Channel          Connectivity
cluster2-node01     out-of-band      full-connectivity
cluster2-node02     out-of-band      full-connectivity
2 entries were displayed.
cluster2::> storage shelf acp show -instance
             Node: cluster2-node01
          Channel: out-of-band
    Enable Status: true
             Port: e0P
       IP Address: 192.168.2.55
           Subnet: 192.168.0.1
          Netmask: 255.255.252.0
Connection Status: full-connectivity
             Node: cluster2-node02
    Enable Status: true
             Port: e0P
       IP Address: 192.168.1.253
           Subnet: 192.168.0.1
cluster2::> storage shelf acp module show -instance
        Module Name: 1.0.B
       Adapter Name: 0a
        MAC Address: 00:a0:98:c6:ea:91
           IOM Type: iom6e
Shelf Serial Number: SHJHU1702000451
         IP Address: 192.168.2.145
   Protocol Version: 2.1.01.22
   Firmware Version: 01.22
        Assigner ID: 537067641
              State: connection-error
       Last Contact: 514
        Module Name: 1.0.A
       Adapter Name: 0a
        MAC Address: 00:a0:98:c6:ed:91
           IOM Type: iom6e
         IP Address: 192.168.1.145
              State: active
       Last Contact: 36
        Module Name: 1.0.B
       Adapter Name: 0b
           IOM Type: iom6e
       Last Contact: 514
        Module Name: 1.0.A
       Adapter Name: 0b
           IOM Type: iom6e
              State: active
       Last Contact: 36
cluster2::> system service-processor show
                               IP           Firmware
Node          Type Status      Configured   Version   IP Address
cluster2-node01
              SP   online      true         2.4.1P2   192.168.7.210
cluster2-node02
              SP   online      true         2.4.1P2   192.168.7.211
I need to fix somethings?
Thanks
Cloud Volumes ONTAP
Review Banner
All Community Forums
