I have a FAS3020 filer with 2 DS14MK2 shelfs 2 x ESH2 modules in each. There is currently no data on the disks in this system. I want to add a shelf from my Decomm'd FAS940. It's a DS14MK2 with 2 x ESH modules. Is this compatible? The shelf’s are double connected disk loops for redundancy & load balancing i.e.0a is connected via Fibre to Shelf 1 ESH2 Module A IN with shelf 2 & 3connected accordingly to module A. 0c is connected via Fibre to Shelf 1 ESH2 Module B IN with shelf 2 & 3 connected accordingly to B modules. Shelf 3 has the ESH modules withtermination switch set to on.
Currently Shelf 1 is showing both Loop A and B, shelf 2 and 3 are not. When in maintenance mode, it appears only Shelf 1 is identified by the filer head. Any help on this situation? Thanks.
-B
