ONTAP Hardware
FCoE on FAS 8300
ashrafbinali
Dear All,
please advise FAS 8200 is supports FCoE? If it support, please provide FCoE configuration guide with VMWare?
1 ACCEPTED SOLUTION
AlexDawson
Hi there! Your subject says "FAS8300" but the text says "FAS8200" - so I will answer for both -
Hope this helps!
2 REPLIES 2
AlexDawson
Hope this helps!
ashrafbinali
HI Alex,
Thank you for Reply,
You shared FC Configuration Document, please share FCOE configuration Document,
