ONTAP Hardware
How long does it take to initalize 24-2tb drives for a FAS3140
fhauntsman
Hi, I have been running the drive initalize (4a option) for 6 hours.  Does anyone have an estimate on how long this takes or how to view status.  Serial connected and progress is only showing .....?  Thank in advance
3 REPLIES 3
ekashpureff
I've initialized a few big systems, and I wouldn't think it shouldn't take that long.
You're not seeing any err messages ? Progress is showing ?
Maybe patience is a virtue ?
I hope this response has been helpful to you.
At your service,
Eugene E. Kashpureff
ekashp@kashpureff.org
Fastlane NetApp Instructor and Independent Consultant
http://www.fastlaneus.com/ http://www.linkedin.com/in/eugenekashpureff
(P.S. I appreciate points for helpful or correct answers.)
rkaramchedu1
You should have received an estimate number of minutes to complete the initialization at the start of that process.. I believe the 2TBs take about 6 hrs (should not matter how many drives there are since they occur in parallel). I am a bit surprised that you've been running it for over 6 hrs and it is still going..
fhauntsman
Thanks to all for the replies.  The process took 7 hours.
