ONTAP Hardware
I didn't mount a nfs volume
mecd200000
hello every one.  I have been using fas 3020 and aix 5,3 sytem . Yesterday I need to nfs volume to use a aix system.
first I edited the /etc/exports file and entered commad exportfs -a. The command was succesfully applied. when I entered exportfs,
I saw the line that edited  /etc/exports. after that I treid to mount a volume that have exported on /etc/exports.
The mount was success but It couldn't write a file and directory When I write a file or direcroy, The messages showd me "Permission denied"
I examined all file related nfs setting  "/etc/exports, qtreee". All setting is ok  but the directory that mount pointer is changed owner from root:sys to
weblogic:weblogic  The aix 5.3 system had  weblogic account
I have found a this soultion on netapp community site continue. but I don't find a soulution.
Can anybody help this problem?
* exported volume is   /vol/vol1
* mounter pointer on aix server is /netapp
* the server ip is 192.168.50.5
nas1*> exportfs
/vol/source     -sec=sys,rw,nosuid
/vol/vol0/home  -sec=sys,rw,nosuid
/vol/vol0       -sec=sys,rw,anon=0,nosuid
/vol/vol1       -sec=sys,rw,root=192.168.50.5
/vol/luntest    -sec=sys,rw,nosuid
nas1*> qtree
qtree: This command is deprecated; using qtree status.
Volume   Tree     Style Oplocks  Status
vol0              unix  enabled  normal
vol1              unix  enabled  normal
luntest           mixed enabled  normal
luntest  test     mixed enabled  normal
source            unix  enabled  normal
nfs mount pointer  on aix
before the mount       drwxr-xr-x   2 root     sys          512 Nov 26 12:00 netapp
after   the mount        drwxrwxrwx  2   weblogic  weblogic   512 Nov  2010 netapp
1 REPLY 1
ekashpureff
Which one of these file systems are you trying to write to ?
Output of 'mount' command on aix system would be useful.
Which user are you trying to mount as from aix ?
Open export on /vol/vol0 is scary. Have you set admin host on this system ?
'mixed' security style ( luntest ? ) is something I usualy avoid as well...
I hope this response has been helpful to you.
At your service,
Eugene E. Kashpureff
ekashp@kashpureff.org
Fastlane NetApp Instructor and Independent Consultant
http://www.fastlaneus.com/ http://www.linkedin.com/in/eugenekashpureff
(P.S. I appreciate points for helpful or correct answers.)
