FAS and V-Series Storage Systems Discussions
If spare disk low and found that the disk is offline
newbeee
How do we make it online?
Please advise
Thanks
1 REPLY 1
Re: If spare disk low and found that the disk is offline
YIshikawa
First, you need to identify the reason which makes it offline. If it is just fisk failure, replace it with new disk.
Which version and mode of Data ONTAP you are using? "version" command show you version and mode of Data ONTAP.
In 7-mode, run"sysconfig -r" to check status of disks. "sysconfig -a", "storage show disk" and logs(messages and ems) is also needed.
In Cluster-mode, run each command above by "run -node <nodename> <command>".
Earn Rewards for Your Review!
GPI Review Banner
All Community Forums
