FAS and V-Series Storage Systems Discussions
Highlighted
Is it possible to specify a VLAN for RLM?
Hi all
The FAS3140 has a single management port for e0M and RLM. I would like to place these interfaces in different VLANs, e.g. e0M in VLAN10 and RLM in VLAN20. I can add e0M to a VLAN in Data ONTAP but I can't see any way to specify a VLAN for RLM, is this possible?
If not then will setting the native VLAN of the switch port (that the management port is connected to) to the VLAN I want RLM to communicate with work?
Thanks
1 REPLY 1
No, you can't tag a vlan, jumbo frame or run in 1000mb/s mode on the RLM, check the ontap network management guide for more information.
Cheers,
Forums
