FAS and V-Series Storage Systems Discussions
Highlighted
NetApp cabling
Hi Experts i need help related to cabling.
Is there any way i can gather cabling information through CLI in CDOT. E.g. i have 4 shelfs in 1 stack and i want to understand how they are stacked(port 1 of shelf a is connected to which port of other shelf in stack) . I tried to use CA but dont know why it is not collecting cabling information. Cabling tab is blank in CA. I do not have physical access to storage.
5 REPLIES 5
Highlighted
Re: NetApp cabling
Do you have FC or SAS shelves?
Highlighted
Re: NetApp cabling
do you have any disk shelves?
Highlighted
Re: NetApp cabling
I have SAS shelves connected through ATTO bridges. This is metro cluster confguration.
Highlighted
Re: NetApp cabling
Hi there,
Unfortunately the cabling behind an ATTO bridge isn't visible through the CLI.
Sorry!
Highlighted
Re: NetApp cabling
Cabling behind ATTO bridge can be traced. Here is example of (7-Mode/node shell) storage bridge and environment shelf output:
storage bridge:
SAS Port A:
QSFP Vendor:        Molex Inc.
QSFP Part Number:   112-00177+A0
QSFP Type:          Passive Copper 2m ID:01
QSFP Serial Number: 417721061
environment shelf:
	SAS cable information by element:
	  [1] Vendor: Molex Inc.
	      Type: QSFP passive copper 2m  ID: 00  Swaps: 0
	      Serial number: 417721061  Part number: 112-00177+A0
Just follow serial numbers. Shelf port numbers are documented in SAS adapter connected to misconfigured SAS domain
Try the NEW Knowledgebase!
NetApp KB Site
Forums
