Don't have an account?
ONTAP Hardware
Dear NetApp Gurus,
Would you be kind enough to share your v3240AE installation check list?
Thanks in advance & looking forward to hear from you soon.
Henry
Solved! See The Solution
Hi Henry,
It depends what you mean by installation check list.
These are good starting points.
http://now.netapp.com/NOW/knowledge/docs/ontap/rel802/pdfs/ontap/setup.pdf
http://now.netapp.com/NOW/knowledge/docs/ontap/rel802/pdfs/V-Series/install.pdf
The pdf in the first link has a section called "Configuration information you need to gather" which is a bit like an install check list.
Salute to dominicb!
Thanks
Here’s a video that explains how to change the security style of a volume from Unix to NTFS in ONTAP 9
Join our Discord Community
