FAS and V-Series Storage Systems Discussions
Storage Disk Replace and Root Aggr Disks
ngregory
views-count 1736 Views
This was added to a SOLVED thread... I'm trying a new post to see if it gets any more of a response:
I plan to use VOL MOVE to evacuate all volumes from an aggregate that resides on a shelf in need of replacement.  However, as luck would have it, one of the disks belongs to a root aggregate.  Are there any special concerns with running the "storage disk replace" command against a disk that is part of a root aggr?
Thank you!
Greg
2 REPLIES 2
Re: Storage Disk Replace and Root Aggr Disks
andris
views-count 1737 Views
ngregory
And GO FOR IT I did... took awhile with a 2.42TB SATA disk but all is good.  Never hurts to double-check.  Thanks all who weighed in!
G2 Review Banner
All Community Forums
