ONTAP Hardware
Upgrade to 7.3.6 or 7.3.6P1?
doug_dockter
My FAS2020 is currently on release 7.3.5.1 of Data ONTAP.  Because of the well known bug in this version I'm planning to upgrade to 7.3.6.  Should I go to 7.3.6 or 7.3.6P1?
1 ACCEPTED SOLUTION
scottgelb
P2 is out now... I would go with P2
9 REPLIES 9
scottgelb
mohammedimrankhan
Hi How do i access the P1 or P2 i have looked on the download page but it only has 7.3.6?
Thanks
scottgelb
bottom of download page...select specific software.. Here is a link to 7.3.6P2  http://now.netapp.com/NOW/download/software/ontap/7.3.6P2/
mohammedimrankhan
Thank you very much, that was very quick
For some reason I could not access this from the down load page.
Imran
mohammedimrankhan
One more thing
My browser is not showing the information in order
There are many different versions (M, I, Q)
What is the difference between these versions?
scottgelb
2020 is the "e" code. Elf for 32bit. Make sure you download the correct one. M is for mips, q for 64bit, i for legacy intel.. Make sure you use "e" version for the fas2020.
Typos Sent on Blackberry Wireless
mohammedimrankhan
I am using fas3020c,
Thanks for your help
scottgelb
still e code
mohammedimrankhan
Thanks
