ONTAP Hardware
about aggregation
Enpro
Good day!
Question about aggregation
I have a fas 2720 with 2 controllers and 12 disks. Each controller has 6 disks.
If I create aggregation: 2 aggregations of 6 disks each.
I can assign the owners of these disks to one controller, but then the entire load will be on one controller?
How can I make one aggregation on all disks using the power of two controllers?
1 REPLY 1
jcbettinelli
Hello,
You won't be able to have one single aggregate assigned to two controllers.
One aggregate is assigned to only one controller at a time. It can be re-assigned, but not used by two controllers.
With your system, you should be able to use ADP, partitioning, which at least, should allow to use the 12 disks on the 2 systems by creating partitions. One small partion of the disk assigned to the root aggregate, one partition to controller 1 and the last partition to controller 2.
If you want to have the maximum capacity on only 1 aggregate, I would recommed to go to an Active/Passive configuration where the second controller doesn't have any data aggregate (only root aggregate), and would be only active in a Failover situation.
http://docs.netapp.com/ontap-9/topic/com.netapp.doc.dot-cm-concepts/GUID-B745CFA8-2C4C-47F1-A984-B95D3EBCAAB4.html
http://docs.netapp.com/ontap-9/topic/com.netapp.doc.dot-cm-psmg/GUID-4AC35094-4077-4F1E-8D6E-82BF111354B0.html
