FAS and V-Series Storage Systems Discussions
quota for specific users
SagarDH
Hi,
I have limited quota for 100GB in vol1 for all users. Now in same volume i have provide quota limit 500GB for two users. So how can i do that ? Indivially i can defined for each user but we have so many users. we have FAS 3220 and running in ontap 8.1.4 7 mode. Please guide me
3 REPLIES 3
Re: quota for specific users
Sahana
Hi,
You can use default quotas to apply a quota to all instances of a given quota type. For example, a default user quota affects all users on the system for the specified volume.
https://library.netapp.com/ecmdocs/ECMM1277794/html/smg/GUID-39C97F12-DE7C-4D23-ADF7-C924DAF2A47F.html
You use explicit quotas to specify a quota for a specific quota target, or to override a default quota for a specific target.
https://library.netapp.com/ecmdocs/ECMM1277794/html/smg/GUID-A1DB9563-66D0-4343-B125-33845166F027.html
If this post resolved your issue, help others by selecting ACCEPT AS SOLUTION or adding a KUDO.
SagarDH
Hi Sahana,
Just edited quota file from editor and added last line mannually still it is not taking effect any command has to run to take effect? The way i did is right or i need to foolow other way?
#Auto-generated by setup Mon Apr 18 22:29:43 GMT 2016
*       user@/vol/home2 104857600K      -       101711872K      99614720K       -
*       user@/vol/home1 104857600K      -       99614720K       99614720K       -
suresh  user@/vol/home1 504857600K      -       45000000K       45000000K       -
Naveenpusuluru
Hi @SagarDH
Its better to use system manager GUI for quotas.
G2 Review Banner
All Community Forums
