General Discussion
EDB to PST Conversion tool
Exchange EDB to PST Conversion is one of best ways to perform EDB data recovery. And to accomplish this one needs a professional third party utility that has the capability to restore all your data from even most heavily corrupted databases without any issues. While there are several such tools available in the market, it is better to use the one which is trusted and used by thousands of Exchange admins across the globe such as EdbMails
There are several reasons to use the EDB to PST tool from EdbMails. Let is touch upon some of them below:
Public Folder Recovery: A lot of organizations make use of mail-enabled public folders to facilitate collaboration. If you have your Public folder data in EDB file, then you can have it recovered easily using EdbMails. All your public folder data such as mails, calendar etc. can be exported to Outlook PST while maintaining the original hierarchy. You can also migrate the public folder data to Office 365 Public folder or Live Exchange Server Public folder.
Deleted mailbox recovery: There can be often times where you have to deal with unintentional mailbox deletions. This is where EdbMails EDB to PST Converter comes in. Once the EDB recovery operation is completed, EdbMails will list all the deleted mailboxes in a tree view. From here, you can select the mailboxes that you want and recover them.
Archive mailbox Recovery: Convert all the archive mailbox items in your EDB file to PST file effortlessly. You can also migrate Archive mailbox contents directly to Live Exchange Server or Office 365 account with the help of EdbMails
Recovery Exchange from crash: Retrieve all the information from your dismounted EDB file even after a Exchange Server crash or failure. EdbMails does not require any Exchange Server services or log files or Active directory for performing the recovery operation unlike other native tools.
Automatic Impersonation rights: The application is capable of setting Automatic impersonation rights, making it extremely easy for even a non-technical user to perform EDB recovery and migration. All you have to do is provide the right credentials and EdbMails can handle the rest for you.
3 REPLIES 3
Re: EDB to PST Conversion tool
Microsoft Exchange EDB to PST Converter from Shoviv is a unique solution to convert EDB to PST, EML, and MSG format. This solution works smoothly with all versions of MS Exchange and exports them into Office 365 and live Exchange server. Users can repair severely corrupted EDB files and recover deleted items from EDB file in a hassle-free manner.
Read More: http://www.edbmailrecovery.com/
With the help of an EDB to PST converter software, it is very easy to solve EDB corruption issues and convert them into accessible PST formats. It supports to recover deleted or inaccessible mailbox items from EDB file. This tool also enables to export EDB file in PST, Live Exchange Server and Office 365. For more, visit:  https://www.nucleustechnologies.com/edb-to-pst.html
Follow the below steps for the conversion: Run Stellar Converter for EDB Select your EDB file from ‘Browse’ option Click ‘Next’ button to start the conversion process Click 'Save' to save EDB file into Different file formats Select ‘PST’ option to export Exchange mailboxes into PST format Browse the destination & Click OK. The software will scan the EDB file and list the Exchange mailboxes in a tree-structure view. Check the preview of Exchange mailboxes and save them at a destination location. Regards, Adrian
Forums
