General Discussion
Highlighted
How to convert NSF to PST accurately?
One can easily convert NSF to PST without any data damage or modification with SysInspire NSF to PST converter software. User can extract damage Lotus Notes NSF file and then export it into various file formats such as Outlook PST, EML, HTML, MSG, and others. The process needs a selection of NSF folder from the machine and selection of file format and its done. The outlook is not needed for this process and each element of the Notes mailbox can be recovered easily with all Meta properties intact with it. A free version is also available for trial of this software with any time and anywhere support to all users.
Explore more about Lotus Notes to Outlook here.
4 REPLIES 4
Re: How to convert NSF to PST accurately?
Thanks for the information!
When a Lotus Notes user switch to MS Outlook, then migration of NSF data to PST format is become an essential task. If we search to know about Lotus Notes to Outlook migration process, then we would find that there are two method to convert IBM Notes emails to Outlook PST file - a manual trick and a professional tool. The manual trick is the time-consuming process and highly risk of losing data if does not perform accurately. Therefore, users should go with third-party professional tool for flawless NSF to PST migration.
Know more - http://www.nsfpst.org/blog/free-method-to-convert-lotus-notes-nsf-files-to-ms-outlook-pst-files/
The most popular method to convert NSF to PST is by the use of intelligent software like eSoftTools NSF to PST converter. It can restore NSF files into many different file formats such as PST, EML, EMLX, HTML, MSG, and others. User can export any item of Lotus Notes mailbox including deleted items. Items which are restored remains in same hierarchical order as the original. A demo is also freely and easily available on the official website of eSoftTools.
Know more about free NSF to PST converter here.
There are various professional software available, by which you can instantly convert Lotus Notes emails to Outlook (NSF to PST) format. I would like to suggest you such a perfect software Tool to Convert NSF to PST. More Info:- https://www.tooltoconvert.com/nsftopst.html
Forums
