Legacy Product Discussions (RO)
S500 - Serial Connectivity - Login
theknoxschool
My S500 lost its connectivity when i tried to trunk the two network cards.
I can serial in using HyperTerminal and the the following settings 9600 8-n-1 and i can see the machine but i can not interact with it.
It presents me with a log in screen but i can not type anything into the terminal.
Is there a setting that i am missing, is there something that i should be doing.
Any help would be appreciated.
1 REPLY 1
i3_nheusel
I have an S550 and the default HyperTerminal settings work fine (same as the settings you list).  Are you sure you have the proper null modem cable?
