I have an old FAS270 that I want to put back into action. everything works on it but the web interface. I am attaching a webshot of the errors. Any help wwould be appreciated.
I would re-push ONTAP again... and check if tls is disabled on the browser.. or tls.enable on the controller. The latest 7.3.5.1P4 is supported on the 270.. make sure you use the M Mips code.
