Legacy Product Discussions (RO)
Wrong disk size during replacement
wojciech_bajorek
Hi,
I have FAS270 with 146GB FC disks. Unfortunately one disk failed and I provided a replacement - exact model.
Drive was used somewhere else and had data on it. When I inserted the disk, system rejected it and marked as failed (unknown data on disk).
I managed to bring it as a spare with disk unfail -s <disk_id>, however disk has lower size than other disks (0b.26).
I tried with disk zero spares command, but that didn't change anything.
Sysconfig -r output:
Aggregate aggr0 (online, raid_dp) (block checksums)
  Plex /aggr0/plex0 (online, normal, active)
    RAID group /aggr0/plex0/rg0 (normal)
      RAID Disk Device  HA  SHELF BAY CHAN Pool Type  RPM  Used (MB/blks)    Phys (MB/blks)
      dparity   0b.16   0b    1   0   FC:B   -  FCAL 10000 136000/278528000  137422/281442144
      parity    0b.17   0b    1   1   FC:B   -  FCAL 10000 136000/278528000  137422/281442144
      data      0b.18   0b    1   2   FC:B   -  FCAL 10000 136000/278528000  137422/281442144
      data      0b.19   0b    1   3   FC:B   -  FCAL 10000 136000/278528000  137422/281442144
      data      0b.20   0b    1   4   FC:B   -  FCAL 10000 136000/278528000  137422/281442144
      data      0b.21   0b    1   5   FC:B   -  FCAL 10000 136000/278528000  137422/281442144
      data      0b.22   0b    1   6   FC:B   -  FCAL 10000 136000/278528000  137422/281442144
      data      0b.23   0b    1   7   FC:B   -  FCAL 10000 136000/278528000  137422/281442144
      data      0b.24   0b    1   8   FC:B   -  FCAL 10000 136000/278528000  137422/281442144
      data      0b.25   0b    1   9   FC:B   -  FCAL 10000 136000/278528000  137422/281442144
      data      0b.29   0b    1   13  FC:B   -  FCAL 10000 136000/278528000  137422/281442144
      data      0b.27   0b    1   11  FC:B   -  FCAL 10000 136000/278528000  137422/281442144
      data      0b.28   0b    1   12  FC:B   -  FCAL 10000 136000/278528000  137422/281442144
Spare disks
Spare disks for block or zoned checksum traditional volumes or aggregates
spare           0b.26   0b    1   10  FC:B   -  ATA  10000 68000/139264000   124457/254888432
What is really strange in here is that TYPE = ATA, while the rest of the disks = FCAL. Why is that so?
What can I do to make this new disk as a real spare?
Thank you in advance.
6 REPLIES 6
jayadratha
Hi! Check output of storage show disk and sysconfig -v command.
Maybe you need update Disk Qualification Package file.
https://now.netapp.com/Knowledgebase/solutionarea.asp?id=kb50298
http://now.netapp.com/NOW/download/tools/diskfw/
It helps for me.
wojciech_bajorek
Thanks for the proposal.
I checked these qual_devices* files on my filer and I what is really strange here is that size of these files is bigger than sizes of the files downloaded from now.netapp.com.
Is this correct? (files on my filer are quite old = 2007)
sysconfig -v output:
                 ID     Vendor   Model            FW    Size
                 16: NETAPP   X274_HPYTA146F10 NA03 136.0GB (281442144 520B/sect)
                 17: NETAPP   X274_HPYTA146F10 NA03 136.0GB (281442144 520B/sect)
                 18: NETAPP   X274_HPYTA146F10 NA03 136.0GB (281442144 520B/sect)
                 19: NETAPP   X274_HPYTA146F10 NA03 136.0GB (281442144 520B/sect)
                 20: NETAPP   X274_HPYTA146F10 NA03 136.0GB (281442144 520B/sect)
                 21: NETAPP   X274_HPYTA146F10 NA03 136.0GB (281442144 520B/sect)
                 22: NETAPP   X274_HPYTA146F10 NA03 136.0GB (281442144 520B/sect)
                 23: NETAPP   X274_HPYTA146F10 NA03 136.0GB (281442144 520B/sect)
                 24: NETAPP   X274_HPYTA146F10 NA03 136.0GB (281442144 520B/sect)
                 25: NETAPP   X274_HPYTA146F10 NA03 136.0GB (281442144 520B/sect)
                 26: HITACHI  HUS103014FLF210  MS04  68.0GB (286749486 512B/sect)
                 27: NETAPP   X274_HPYTA146F10 NA03 136.0GB (281442144 520B/sect)
                 28: NETAPP   X274_HPYTA146F10 NA03 136.0GB (281442144 520B/sect)
                 29: NETAPP   X274_HPYTA146F10 NA03 136.0GB (281442144 520B/sect)
26 is the new disk. Any new ideas how to make it visible as the rest of the disks?
lwei
What's the source of the disk 26? It shows Hitachi, not NetApp. Are you sure it's the correct disk? If so, maybe you need to update disk firmware.
Thanks,
Wei
jayadratha
It looks like original Hitachi disk:
HITACHI HUS103014FLF210 ULTRASTAR 10K300 147GB 10KRPM 16MB FIBER CHANNEL 40PIN SCA-2 3.5" HARD DRIVE
Of course you can download latest fw pack for drives and manualy update fw (disk_fw_update).
But i think it doesn't help.
If you get this drive from NetApp you need contact with support.
moncyvarghese
Hi ,
Please try upgrading the Ontap  , it should take care of the issue.
regards
moncy
canvasstorage
This is older so you may have solved it.  One thing I noticed... the replacement disk is 512 block, original disks are 520 block.
Can't replace 520B drives with 512B drives.
