NetApp University Discussions
Highlighted
O tap simulator on VMware worksration small screen
Hi,
i loaded the silulator on VMware workstation 12  and the creek resolution is really small. How can I fix this to give me the proper sizes?
screen is way too small to even see much to be able to install tools or drivers.
any suggestions?
thank you!
1 REPLY 1
Re: O tap simulator on VMware worksration small screen
I don't believe you can change that setup.
There should be no need to install vmware tools - the mks interface in vmware should only be used to setup networking, and from that point, use SSH or the OnCommand System Manager web interface to manage the system
Forums
