Network Storage Protocols Discussions
Setuid not working without read access in NFSv4
kukacz123
views-count 2270 Views
Hi,
I'm having issues with setuid/setgid programs after upgrade (move to c-DOT) from NFSv3 to NFSv4 access protocol.
Apparently, programs with "setuid/setgid" bit set work as they should only when also "read" permission is set on the executable file. That's different from NFSv3, where setuid bit only without read access on file is enough to execute.
I have the same volume mounted once through NFSv3 and once using NFSv4 (parallel NFS):
[testuser@edud01sap02 ~]$ mount|grep NFS
vssaptest5001:/vssaptest5001_edu_bench1 on /mnt-NFSv3 type nfs (rw,vers=3,addr=10.243.66.50)
vssaptest5001:/vssaptest5001_edu_bench1 on /mnt-NFSv4 type nfs (rw,vers=4,minorversion=1,addr=10.243.66.50,clientaddr=10.243.66.62)
The access rights:
[testuser@edud01sap02 ~]$ ls -l /mnt-NFSv3/setuidtest
-r-s--s---. 1 otheruser otheruser 7018 Aug 16 19:31 /mnt-NFSv3/setuidtest
[testuser@edud01sap02 ~]$ ls -l /mnt-NFSv4/setuidtest
-r-s--s---. 1 otheruser otheruser 7018 Aug 16 19:31 /mnt-NFSv4/setuidtest
I got "permission denied" error when trying to execute through NFSv4:
[testuser@edud01sap02 ~]$ /mnt-NFSv4/setuidtest
-bash: /mnt-NFSv4/setuidtest: Permission denied
... while the same file executes correctly through NFSv3:
[testuser@edud01sap02 ~]$ /mnt-NFSv3/setuidtest
uid=555 euid=666
gid=555 egid=666
When I set the read access bit for group owner, the program executes also through NFSv4:
[testuser@edud01sap02 ~]$ sudo chmod g+r /mnt-NFSv4/setuidtest
-r-sr-s---. 1 otheruser otheruser 7018 Aug 16 19:31 /mnt-NFSv4/setuidtest
uid=555 euid=666
gid=555 egid=666
Is this something what has changed since NFSv3 or do I miss some configuration? This is an 8.2.1 c-DOT system with SetUID option enabled in export-policy:
Honor SetUID Bits in SETATTR: true
This behaviour prevents our systems from executing programs which do have strict access mode validation hardcoded to perform before proceeding with execution. Therefore just adding that "read" permission is not a valid workaround for me.
Best regards,
Lukas
G2 Review Banner
All Community Forums
