Network and Storage Protocols
Running exportfs is different than /etc/exports
BOB_KOCHANSKI
I just ran a wiregauge report on a customer's HA system and both are reporting back: Running exportfs is different than /etc/exports
Any ideas what this means or has anyone come across this before?
Thanks,
Bob
5 REPLIES 5
baijulal
Please try running
Filer>exportfs
Filer>rdfile /etc/exports
Look for any difference in exports in memory and exports defined in the conffile, update /etc/exports with if any and re ran the tool.
BOB_KOCHANSKI
How do I go about comparing the exports file in Memory?
Thanks,
RichardSopp
The exportfs command will give you the exports currently held in memory
BOB_KOCHANSKI
Thanks for the reply, this has been resolved.
Thanks again,
ajeffrey
Hi Bob,
It seems like someone has manually exported a path without adding it to the exports file.  Two options are to find the discrepancy and fix the exports file as in the above post or make sure the exports file is correct and then run:
exportfs  -r
Exports  all  file  system paths specified in the /etc/exports file and unexports all  file  system paths not specified in the /etc/exports file.
Regards,
Jeff
