Network and Storage Protocols
Script for NFS volume create and export
GERNETAPP
Hi to all,
   I just want to know if someone could give me a hand or a tip or maybe someone has already done a script in Linux for creating a NFS volume and also to add the entry to the /etc/exports file in the FAS.
Thanks in advance,
Best regards,
German
1 REPLY 1
bulent_goktas
Hi mate
Here is the example script
host files should be right config on where its running script
#!/bin/bash
# Create the NFS volumes for the first 2 nodes on the storage systems $STORAGE1 and $STORAGE2
STATUS=false
SPACE=6000000000
SPACE1=0
SPACE2=0
STORAGE1="NETAPP-1"
STORAGE2="NETAPP-2"
ping -c 1 $STORAGE1 >/dev/null 2>&1
if [ $? != 0 ]; then
    echo "Cannot ping the filer $STORAGE1"
    exit 8
fi
ping -c 1 $STORAGE2 >/dev/null 2>&1
    echo " Cannot ping filer $STORAGE2"
    exit 8
fi
echo "ping to both filer is okay"
SPACE1=`ssh $STORAGE1 aggr show_space |grep "Total space      " |awk '{print $5}' | cut -d"K" -f1`  >/dev/null 2>&1
SPACE2=`ssh $STORAGE2 aggr show_space |grep "Total space      " |awk '{print $5}' | cut -d"K" -f1`  >/dev/null 2>&1
echo "Available Space in aggr0 on $STORAGE1 = $SPACE1 KB"
echo "Available Space in aggr0 on $STORAGE2 = $SPACE2 KB"
if [ $SPACE1 -lt $SPACE ] ; then
    echo "Filer $STORAGE1 does not have enough space exiting here!!!"
#    exit 8
fi
if [ $SPACE2 -lt $SPACE ] ; then
    echo "Filer $STORAGE2 does not have enough space exiting here!!!"
#    exit 8
fi
echo " Creating NFS Volumes on $STORAGE1"
ssh $STORAGE2 vol create TEST_VOL_01 aggr0 50g
ssh $STORAGE2 vol options TEST_VOL_01 nosnapdir on
ssh $STORAGE2 vol options TEST_VOL_01 nosnap on
ssh $STORAGE2 exportfs -p sec=sys,rw=[fec0::]/64,root=[fec0::192:168:201:6],anon=0 /vol/TEST_VOL_01
ssh $STORAGE2 vol create TEST_VOL_02 aggr0 50g
ssh $STORAGE2 vol options TEST_VOL_02 nosnapdir on
ssh $STORAGE2 vol options TEST_VOL_02 nosnap on
ssh $STORAGE2 exportfs -p sec=sys,rw=[fec0::]/64,root=[fec0::192:168:201:6],anon=0 /vol/TEST_VOL_02
