Network and Storage Protocols
Starting with netapp need help iscsi problem
SCHATTENZEIT
Hello from Berlin !
I am new here, and I have a problem installing iscsi with netapp.  Maybe, general Problem
My system: two nodes with oracle Linux 6.5
When  I  run discovery, it seems to be ok:
#  iscsiadm -m discovery -t st -p 10.40.30.246:3260 –login
10.40.30.246:3260,2001 iqn.1992-08.com.netapp:sn.2014386705
But result of:
#iscsiadm -m node -T  iqn.1992-08.com.netapp:sn.201438670  -p 10.40.30.246 –l
iscsiadm: No records found
in the /var/log/messages I find when I restart  service:
#service iscsi  restart
Message:
Feb 17 12:21:26 dbb-n15-01 iscsid: Connection2:0 to [target: iqn.1992-08.com.netapp:sn.2014386705, portal: 10.40.30.246,3260] through [iface: default] is shutdown.
Feb 17 12:21:26 dbb-n15-01 kernel: scsi5 : iSCSI Initiator over TCP/IP
Feb 17 12:21:27 dbb-n15-01 iscsid: Could not set session3 priority. READ/WRITE throughout and latency could be affected.
Feb 17 12:21:27 dbb-n15-01 iscsid: Connection3:0 to [target: iqn.1992-08.com.netapp:sn.2014386705, portal: 10.40.30.246,3260] through [iface: default] is operational now
Maybe a newbie problem, but  I hope you can help me
Thanks a lot
Micha
1 ACCEPTED SOLUTION
SCHATTENZEIT
Hi,
the problem is fixed:
we had to add the InitiatorName  to the igroup
3 REPLIES 3
rwelshman
What is the configuration on the filer look like in terms of assigning LUNs to those servers via iSCSI?
SCHATTENZEIT
Hello Riley,
thanks for your Answer     The  LUNS are in a inititator group RAC_N15, cause I want to use them as
raw devices. Maybe there is a little bit more I have to do ?   We use Oracle  11g, but for a new project Oracle 12c (with asm)
RAC.
Greetings from Berlin
Michael
SCHATTENZEIT
Hi,
