Network and Storage Protocols
fas2040 network problems
STEVEP38NOW
Just bought a new fas2040 and am trying to setup the network ports. Used the setup script and got the following:
e0P: flags=0x2708866<BROADCAST,RUNNING,MULTICAST,TCPCKSUM> mtu 1500
        ether 00:a0:98:2a:05:86 (auto-unknown-down) flowcontrol full
e0a: flags=0x2f48867<UP,BROADCAST,RUNNING,MULTICAST,TCPCKSUM> mtu 1500
        inet 10.1.70.210 netmask 0xffffff00 broadcast 10.1.70.255
        ether 00:a0:98:2a:05:8b (auto-1000t-fd-up) flowcontrol full
e0b: flags=0x2f48867<UP,BROADCAST,RUNNING,MULTICAST,TCPCKSUM> mtu 1500
        inet 10.1.70.211 netmask 0xffffff00 broadcast 10.1.70.255
        ether 00:a0:98:2a:05:8a (auto-1000t-fd-up) flowcontrol full
e0c: flags=0x2f48867<UP,BROADCAST,RUNNING,MULTICAST,TCPCKSUM> mtu 1500
        inet 10.1.70.212 netmask 0xffffff00 broadcast 10.1.70.255
        ether 00:a0:98:2a:05:89 (auto-1000t-fd-up) flowcontrol full
e0d: flags=0x2f48867<UP,BROADCAST,RUNNING,MULTICAST,TCPCKSUM> mtu 1500
        inet 10.1.70.213 netmask 0xffffff00 broadcast 10.1.70.255
        ether 00:a0:98:2a:05:88 (auto-1000t-fd-up) flowcontrol full
lo: flags=0x1b48049<UP,LOOPBACK,RUNNING,MULTICAST,TCPCKSUM> mtu 8160
        inet 127.0.0.1 netmask 0xff000000 broadcast 127.0.0.1
        ether 00:00:00:00:00:00 (VIA Provider)
losk: flags=0x40a400c9<UP,LOOPBACK,RUNNING> mtu 9188
        inet 127.0.20.1 netmask 0xff000000 broadcast 127.0.20.1
Destination      Gateway            Flags     Refs     Use  Interface
default          10.1.70.1          UGS         1       44  e0a
10.1.70/24       link#4             UC          0        0  e0a
10.1.70.1        link#4             UHRL        1       11  e0a
PMISPLHSAN01     0:a0:98:2a:5:8b    UHL         0        5  lo
PMISPLHSAN01-e0b 0:a0:98:2a:5:8a    UHL         0        1  lo
PMISPLHSAN01-e0c 0:a0:98:2a:5:89    UHL         0        1  lo
PMISPLHSAN01-e0d 0:a0:98:2a:5:88    UHL         0        1  lo
127              localhost          UGS         0        0  lo
localhost        localhost          UH          1        0  lo
localhost-10     localhost-20       UHS         2        2  losk
localhost-20     localhost-20       UH          0        0  losk
If I just configure the last two ports its fine and I can ping my gateway etc, but if all four are configured I can't ping my gateway anymore. Any help would be appreciated. Also, is there a way to edit the /etc/rc file directly?
Thanks
2 REPLIES 2
andrc
It is a strange one, when all four ports are configured and up can they all be pinged by other hosts on the subnet?
You can edit the /etc/rc file using the `rdfile` and `wrfile` commands but please be aware `wrfile` is not like vi and overwrites the whole file unless you use the `-a` option to append a line. Other options are to use FilerView to configure network interfaces or access the /etc/rc file through the rootvol CIFS share or NFS export and use a text editor.
STEVEP38NOW
Andrc,
Thanks for taking the time to reply. I found the anwser. I needed to put the nics in single mode and after that it worked fine.
