ONTAP Discussions
Problem with hw_assist settings
bosko_radivojevic
Hi all,
I have a new 3240EA system (two controllers in two different enclosures) and have some troubles with hw_assist feature configuration. It is 8.0.2 7-Mode ONTAP version.The problem manifestation is the following:
NAS-THQ-1A> cf hw_assist test
cf hw_assist Error: No response from partner(NAS-THQ-1B), timed out.
NAS-THQ-1B> cf hw_assist test
cf hw_assist Error: No response from partner(NAS-THQ-1A), timed out.
NAS-THQ-1A> cf hw_assist status
Local Node(NAS-THQ-1A) Status:
        Active: NAS-THQ-1A monitoring alerts from partner(NAS-THQ-1B)
        port 4444 IP address x.y.z.121
        Missed keep alive alert from partner(NAS-THQ-1B).
                 No keep alive alert received from partner since last boot.
Partner Node(NAS-THQ-1B) Status:
        Active: NAS-THQ-1B monitoring alerts from partner(NAS-THQ-1A)
        port 4444 IP address x.y.z.122
NAS-THQ-1B> cf hw_assist status
Local Node(NAS-THQ-1B) Status:
        Missed keep alive alert from partner(NAS-THQ-1A).
Partner Node(NAS-THQ-1A) Status:
But, it looks everyting is ok:
NAS-THQ-1A> ping x.y.z.122
x.y.z.122 is alive
NAS-THQ-1B> ping x.y.z.121
x.y.z.121 is alive
NAS-THQ-1A> ifconfig e0M
e0M: flags=0x2b4c867<UP,BROADCAST,RUNNING,MULTICAST,TCPCKSUM> mtu 1500
        inet x.y.z.121 netmask 0xfffffff8 broadcast x.y.z.127
        ether 00:a0:98:16:bb:84 (auto-100tx-fd-up) flowcontrol full
NAS-THQ-1B> ifconfig e0M
        inet x.y.z.122 netmask 0xfffffff8 broadcast x.y.z.127
        ether 00:a0:98:15:d5:6c (auto-100tx-fd-up) flowcontrol full
NAS-THQ-1A> options cf.hw_assist
cf.hw_assist.enable          on
cf.hw_assist.partner.address x.y.z.122
cf.hw_assist.partner.port    4444
NAS-THQ-1B> options cf.hw_assis
cf.hw_assist.partner.address x.y.z.121
NAS-THQ-1A> cf status
Cluster enabled, NAS-THQ-1B is up.
Interconnect status: up.
NAS-THQ-1B> cf status
Cluster enabled, NAS-THQ-1A is up.
What is wrong? Thanks.
1 ACCEPTED SOLUTION
peter_lehmann
For cf hw_assist to work you need the RLM to be configured... Is it?
*snip*
Requirements for hardware-assisted takeover
The hardware-assisted takeover feature is available only on systems that support Remote LAN Modules (RLMs) and have the RLMs installed and set up. The remote management card provides remote platform management capabilities, including remote access, monitoring, troubleshooting, logging, and alerting features.
*snip*
Peter
3 REPLIES 3
peter_lehmann
*snip*
*snip*
Peter
bosko_radivojevic
Yup, that sounds reasonable. Thanks.
ps. Actual instructions to setup RLM could be found on http://now.netapp.com/NOW/knowledge/docs/ontap/rel801/html/ontap/sysadmin/GUID-10633784-DEFF-47A9-891A-AA57C2A8FC68.html
RichardTodd
I just thought I would add to this post to save people some time resolving hw_assist timeout issues with a Service Processor (SP):
Firstly check SP speed / duplex, type 'sp status' and check SP has negotiated 100Mb / Full, if not reconfigure SP network switch ports to auto / auto i.e. speed / duplex.
Once this has been completed type 'sp status' to confirm 100Mb / full duplex, if the output still shows 100Mb / half duplex, type sp reboot and use sp status to confirm reboot has completed and speed / duplex is set correctly.
Another reason for getting time out messages is if the SP has not been configured properly. This may be observed by a SP prompt without hostname i.e. 'SP>'. The SP prompt should be 'SP hostname>'
To fix this issue use the following commands:
sp status
options sp.setup off
sp setup (using info from sp status)
cf hw_assist test
cf hw_assist status
I hope this helps.
