ONTAP Discussions
difference between DEDUPLICATION and COMPRESSION
Rawat_Sunil
1. What is the difference between DEDUPLICATION and COMPRESSION
2. What is the command for both of them.
3. Is we schedule it?
4 REPLIES 4
mikkisse
Hello!
Here is nice document http://www.netapp.com/us/media/tr-3966.pdf
Shortly:
Deduplication does not compress bloks, it keeps one block of data, and other similar blocks presents as link to this block.
You can run deduplication manually, or by schedule.
Compression works only with turned deduplication. If you want to use compression, you must turn on deduplication first.
Compression can be inline and postprocess:
1. Inline - Online compressing your blocks, but slowing perfomance.
2. Postprocess - Compressing blocks by schedule. eg at night or weekend.
Both of this technologies you can turn on at volume's storage efficiency tab in OnCommand System Manager.
Rawat_Sunil
thanks for revert
what is the command for deduplication and compression
mikkisse
You can use volume efficiency command family.
oh, sorry this works at cDOT.
Rawat_Sunil
Compression and postprocess compression not able to implement.
it showing
dr-fas3140a> sis config -C true -I true /vol/vmfs_win003
config: Invalid option - C
sis config [ [ -s schedule ] <path> | <path> ... ]
- Sets up, modifies, and retrieves the schedule of SIS volumes.
dr-fas3140a>
