ONTAP Hardware
Caddy 111-00721-+A1
Khatri
Hi, not sure if this is in the right board, but here it goes. I am looking for a Caddy for NAJ-1501. Mine has the label 111-00721+A1, however, all I can find online are 111-00721+A0 ... Are these compatible with each other? I don't want to end up with the wrong item..
https://www.bargainhardware.co.uk/netapp-111-00721-a0-sff-hs-caddy
1 ACCEPTED SOLUTION
AlexDawson
Yes, they are compatible - we only care about the 111-00721 internally. Usually the different numbers will be different batches or manufacturers for this item.
1 REPLY 1
AlexDawson
