ONTAP Hardware
Disk is seen as partner by both Controllers after replacement.
DarrenAllott
Hello All
I have just replaced a failed disk (5c.23.11) in one of our FAS6210. The disk was owned by controller 1 at the time. Once the disk was replaced after a minute are so, the amber led comes on and the disk cannot be seen in the cLi (disk show, vol status -s / -f etc). Logged onto system manager and it shows as a partner disk on both controllers? There were 2 failed disks at the time. The first replaced ok. I have also tried 3 new disks.
NetApp Release 8.2.3P3 7-Mode
BIR-NETAPP01> disk show 1c.23.11                    -------------------->> (now labled as 1c.23.11)
DISK OWNER POOL SERIAL NUMBER HOME DR HOME
BIR-NETAPP01> disk show -n
disk show: No unassigned disks
BIR-NETAPP01> vol status -f
Broken disks (empty)
Controller1 disks
Controller 2 Disks
Has anyone see this before?
Cheers
6 REPLIES 6
Sahana
Hi,
Before proceeding with the following commands, make sure that the disk in question is not currently in a RAID group. If it is, copy the disk to a spare disk with the following command:
:::> storage disk replace -disk <CDOT disk ID > -replacement <CDOT disk ID of spare disk>  -action start
Disable autoassign
Remove disk ownership
Check if disk is unassigned.
Now assign owner to the unassigned drive manually
Turn on autoassign
If this post resolved your issue, help others by selecting ACCEPT AS SOLUTION or adding a KUDO.
DarrenAllott
Hi, sorry to say, this did not resolve the issue.
xandervanegmond
Hi Darren,
Have you tried to check whether the disk is visible at all in a sysconfig -a on either node?
If the disk is present there, try using the disk show -a to see if it shows up and what the owning serial number is.
It could be the disk is a refurbished one where the disk ownership was not removed fully.
/Xander
colsen
I've not run into this specifically but maybe just start by removing the disk ownership from the "offending" disk and then assigning it directly to the correct node:
https://library.netapp.com/ecmdocs/ECMP1368859/html/GUID-84934533-63CA-4A73-82DB-31BBF768C1E8.html
Good luck,
Chris
DarrenAllott
@xandervanegmond Many thanks, as you stated, the disk was a refurb and still had assignment to its old Filer. Using disk assign -f sorted the issue.
Cheers
rmontavonsa
