Talk and ask questions about NetApp FAS and AFF series unified storage systems. Talk with other members how to optimize these powerful data storage systems.
The message you are trying to access is permanently deleted.
we have AFFA50 We have IO Module X60130A with 2 ports ,Out of 2 ports does one port can be used for Optical with transreceiver and and other for Ethernet(Copper) . We are planning to use one port for storage and one port for Data as part of Dual NIC does it supports.
... View more
Dear everyone, When performing an ONTAP upgrade on NetApp systems, we observe an I/O interruption lasting approximately 10 to 30 seconds, which causes all applications to terminate. This interruption occurs frequently during the upgrade process, and we are looking for ways to minimize its impact. We have tested the following upgrade approaches: 1. Manual takeover using the storage failover takeover command 2. Step-by-step takeover (LIF migration → CFO takeover → SFO takeover) 3. ANDU (Automated Non-Disruptive Upgrade) We confirmed that I/O interruption occurs with all of the above methods. Among them, option 2 (step-by-step takeover) results in the least impact, but the interruption is still noticeable. This issue does not appear to be related to system utilization, and we have observed that it occurs more frequently on ONTAP 9.12.1 and later versions, even when running the latest patch releases. We would appreciate your advice on: Whether this behavior is expected in recent ONTAP versions Any known issues or changes in takeover/upgrade behavior since 9.12.1 Best practices or configuration recommendations to further reduce or eliminate this I/O interruption during upgrades. Thank you.
... View more
Hi, I'm curious if there is any leeway in supported hardware for EOA/EOS systems, such as a FAS8020. Have a customer running 8.2.3 7-mode and wanting to add about 800TB of capacity, but we want to use larger drives than the officially-supported max of 6TB per spindle. I do see at higher ONTAP versions, more supported disks come into the fold, but was wondering if anyone had successfully gone outside of the HWU boundaries before. Thanks!
... View more
Hi, I would like to replace spare 6 x SAS disks with 6 x 960 GB SSD disks to create a new full ssd aggregate (raidDP). The system FAS2750 has internal controller chassis DS224-12 and 1 additional shelf DS224-12. May I know is there any preference disk slots/stack for the SSD disks in term of best practice and performance point of views? Thanks.
... View more
We need to perform a task that involves disconnecting one of the cluster interconnect cables as part of a Failover Test and during the transition from a 2-node switchless configuration to a 4-node switched cluster. Because this procedure requires maintaining continuous service, the customer is requesting an official NetApp document or guidance confirming that disconnecting a single cluster cable does not cause any I/O interruption or noticeable I/O fluctuations. In our internal testing, we confirmed that there was no I/O outage; however, we did observe very slight I/O fluctuations. These minor latency spikes appeared to have minimal impact on the virtual machines in the test environment. We would appreciate any official documentation or recommendations from NetApp regarding the service assurance when a single cluster interconnect link is disconnected, including both I/O continuity and the absence of I/O fluctuation.
... View more
