ONTAP Hardware
FAS8080 Flex Array - OCUM warning: Disk Shelf Multipath Not Configured
J-L-B
I have a FAS808EX (OnTap 8.3.2p4) configured as a FlexArray only.  No local attached disk shelves.  The OS boots off another array lun on each node.  1 aggregate is configured on each node with array luns on the same array.
All is running well except OCUM 7 is reporting a warning on both nodes:  Disk Shelf Multipath Not Configured.  Being that there are no local disk shelves, is this something that can be turned off?  The only way to get it to go away on OCUM 7 is to turn off the multipath alerts globally which I don't want to do because I have other nodes on this same cluster and other clusters.
Here's the alert from OCUM:
Severity:  Warning
State:  Acknowledged
Impact Level:  Risk
Impact Area:  Availability
Source:  cluster1_01
Acknowledged By:  ocumadmin (44 Mins Ago)
Resolved By:
Assigned To:
Triggered Time:  1 Hour 5 Mins Ago
Trigger Condition:  Disk shelf has either one or no path connected to the node.
1 ACCEPTED SOLUTION
J-L-B
After contacting support, this issue is due to an OS bug. Bug ID 927715
Although the system is healthy, per their response:  "There is no fix until 9.2 OS is released, till then you need to keep ignoring these alerts."
18 REPLIES 18
