ONTAP Hardware
Failover issue on FAS2554
trumpsbrah
I have a FAS 2554 with 2-nodes running CDoT 8.3.1. The HA status shows me everything is good. Interface groups, failover targets, etc all check out. I have a root aggregate on each node (partitioned as 8.3.1 is wont to do) and an aggregate for a SVM owned by node1. When I initiate a takeover of node1 by node2, everything works fine, node1 reboots normally, giveback works as expected.
However when I do a takeover of node2 by node1, node2 hangs on reboot. Even the SP goes offline. The only thing I can do is a power cable yank at the datacenter. Then, it finally boots into waiting for giveback mode and accepts a giveback.
Anyone ever seen this behavior? We even wiped the config and started over from scratch, but get the same issue when I do failover testing from node2 to node1. I don't see any config or cabling issues, so I'm wondering if there's a problem w/ the node or the interconnect hardware.
Here's some info, but I'm happy to provide anything else that might help someone troubleshoot.
Thanks,
Steve
cluster1::> storage failover show-takeover
Node       Node Status           Aggregate      Takeover Status
node1
           In takeover.
Warning: Unable to list entries on node node2. RPC: Port mapper
         failure - RPC: Timed out
cluster1::> system node run -node node1 -command storage show fault
Enclosure Status: critical
Channel: 0a
Shelf: 0
Shelf Type: DS4246
Product Serial Number: SHJSG1504000090
Module Type: IOM6E
Disk Elements:
Element Status                  Status Bytes  Status Descriptions
  0 [Bay  0]: OK                01,00,00,00
  1 [Bay  1]: OK                01,01,00,00
  2 [Bay  2]: OK                01,02,00,00
  3 [Bay  3]: OK                01,03,00,00
  4 [Bay  4]: OK                01,04,00,00
  5 [Bay  5]: OK                01,05,00,00
  6 [Bay  6]: OK                01,06,00,00
  7 [Bay  7]: OK                01,07,00,00
  8 [Bay  8]: OK                01,08,00,00
  9 [Bay  9]: OK                01,09,00,00
 10 [Bay 10]: OK                01,0A,00,00
 11 [Bay 11]: OK                01,0B,00,00
 12 [Bay 12]: OK                01,0C,00,00
 13 [Bay 13]: OK                01,0D,00,00
 14 [Bay 14]: OK                01,0E,00,00
 15 [Bay 15]: OK                01,0F,00,00
 16 [Bay 16]: OK                01,10,00,00
 17 [Bay 17]: OK                01,11,00,00
 18 [Bay 18]: OK                01,12,00,00
 19 [Bay 19]: OK                01,13,00,00
 20 [Bay 20]: OK                01,14,00,00
 21 [Bay 21]: OK                01,15,00,00
 22 [Bay 22]: OK                01,16,00,00
 23 [Bay 23]: OK                01,17,00,00
Power Supplies:
  1: OK                01,00,00,A0   RQSTED ON
  2: OK                01,00,00,A0   RQSTED ON
  3: OK                01,00,00,A0   RQSTED ON
  4: OK                01,00,00,A0   RQSTED ON
Fans:
  1: OK                01,03,AC,A7
  2: OK                01,03,66,A6
  3: OK                01,03,AC,A7
  4: OK                01,03,66,A6
  5: OK                01,03,AC,A7
  6: OK                01,03,66,A6
  7: OK                01,03,AC,A7
  8: OK                01,03,66,A6
Temperature Sensors:
  1: OK                01,00,21,00
  2: OK                01,00,2B,00
  3: OK                01,00,2A,00
  4: OK                01,00,38,00
  5: OK                01,00,2A,00
  6: OK                01,00,36,00
  7: OK                01,00,2A,00
  8: OK                01,00,36,00
  9: OK                01,00,2B,00
 10: OK                01,00,39,00
 11: OK                01,00,30,00
 12: OK                01,00,30,00
Enclosure Electronics:
  1 [IOM6E A]    : OK                01,00,01,80   REPORT
  2 [IOM6E B]    : OK                01,00,00,80
OPS Panel:
  1: OK                01,00,00,00
Enclosure:
  1: OK                01,00,02,00   FAIL
Voltage Sensors:
  1: OK                01,00,FF,01
  2: OK                01,00,BA,04
  3: OK                01,00,FF,01
  4: OK                01,00,BE,04
  5: OK                01,00,FF,01
  6: OK                01,00,BE,04
  7: OK                01,00,FF,01
  8: OK                01,00,BE,04
Current Sensors:
  1: OK                01,00,82,01
  2: OK                01,00,B7,02
  3: OK                01,00,B7,00
  4: OK                01,00,03,02
  5: OK                01,00,11,01
  6: OK                01,00,E8,01
  7: OK                01,00,21,01
  8: OK                01,00,3E,02
SAS Connectors:
  1: OK                01,3F,FF,00
  2: OK                01,03,FF,00
  3: OK                01,3F,FF,00
  4: OK                01,03,FF,00
Vendor Unique Element 83-IOM6E: (SAS)
  1 [IOM6E A]    : OK                01,08,00,00   MASTER
  2 [IOM6E B]    : OK                01,00,00,00
Vendor Unique Element 85-IOM6E: (ACP)
  1 [IOM6E A]    : OK                01,00,00,00
  2 [IOM6E B]    : CRITICAL          02,00,00,40   FAIL
Vendor Unique Element 88-IOM6E: (PCM)
  1: OK                01,01,00,00
  2: OK                01,01,07,80   PC SHELF FAULT RQSTD
Vendor Unique Element 8B-IOM6E: (ETHERNET)
  1 [IOM6E A]           : OK                01,01,00,00
  2 [IOM6E B]           : OK                01,01,00,00
5 REPLIES 5
Sahana
Hi,
There can be various reasons for giveback to fail. Refer  Why is the giveback of a clustered Data ONTAP aggregate vetoed?
If this post resolved your issue, help others by selecting ACCEPT AS SOLUTION or adding a KUDO.
rymcc86
Hello,
When node two hangs have you tried connecting a console cable to the management port and connecting to the CLI using Putty? I'm not 100% sure this will work with the SP offline, however doing this in the past I have come across issues with the boot loader which loads the ONTAP OS.
You can find more info on the boot loader commands in the NetApp Knowledge base but trying boot_ontap should attempt to load the OS and throw an error if none is visible right away.
All the best,
Ryan
trumpsbrah
Thanks for the responses. A directly-connected serial session to the SP fails, too. The output is frozen until the node is powered off and restarted.
As far as the giveback failing, there is nothing to giveback to until the node gets rebooted. Once that happens, the giveback functions as expected.
rymcc86
At this point, if the linked document above does not help I would recommend raising a support case with NetApp directly to determine the cause of this issue.
All the best,
Ryan
trumpsbrah
Thanks, Ryan. I've got a case open w/ NetApp. They've narrowed it down to either a hardware or a software issue. Smiley Frustrated
