ONTAP Hardware
No anonymous login
bastianernst
Hi,
i try to connect to my netapp ftp server but without success...
My ftp settings: (FAS2040)
ftpd.3way.enable         off
ftpd.anonymous.enable    on
ftpd.anonymous.home_dir  /vol/ftp_test
ftpd.anonymous.name      anonymous
ftpd.auth_style          mixed
ftpd.bypass_traverse_checking off
ftpd.dir.override
ftpd.dir.restriction     off
ftpd.enable              on
ftpd.explicit.allow_secure_data_conn on
ftpd.explicit.enable     off
ftpd.idle_timeout        900s
ftpd.implicit.enable     off
ftpd.ipv6.enable         off
ftpd.locking             none
ftpd.log.enable          on
ftpd.log.filesize        512k
ftpd.log.nfiles          6
ftpd.max_connections     500
ftpd.max_connections_threshold 0%
ftpd.tcp_window_size     28960
Error message:
220 nas-01 FTP server (NetApp Release 7.3.4: Thu May 27 17:52:48 PDT 2010) ready
Name (IP:root): anonymous
331 Guest login ok, send ident as password.
Password:
530 Login incorrect.
ftp: Login failed.
Any ideads?
Thanks!
1 REPLY 1
Jeff_Yao
u need to edit the /etc/passwd file for a local login to have the FTP user added:
for example
ftp::65533:65533:FTP Anonymous:/vol/homedir
and what's the qtree style for ur homedir? should be unix
and u need to export ur homedir in exports file
thanks
Jeff
