ONTAP Hardware
Semi-Nube FAS2020 Capacity issue
mvetteplex
We have a Fas2020 ,that has 9 207GB drives in an aggregate configuration, Properties show type traditional, online, raid_dp. The system showed that 85% of the drive is used and we had 4 spares so we added two of the spares to the configuration. The total capacity before adding the two drives was listed as 592 GB and after adding the drives is still listed as 592 GB. So doing remedial math, we have 9 200 GB drives that should = 1.8TB of space I know that two of the drives are being used for Parity so we are now @ 1.4 TB.
The big question is whay are we missing 800GB of sapce and why adding two drives didn't change the space available.
I "lucked" into helping with this system and need ll of the hlp I can get.
Thanks Mike
5 REPLIES 5
lwei
Hi Mike,
Did you expand the RAID-DP group size before adding the two drives? If not, it may add a new group in the aggregate and the two new drives become parity drives.
How much space is reserved by the aggregate and/or volume(s)? That might explain the difference.
Thanks,
Wei
mvetteplex
lwie,
Thanks, that at least gives me a direction to look, no we didn't expand the raid-dp before we added the new, it also doesn't look like it made a new group, here is what I see:
aggr status -r
Aggregate vol1 (online, raid_dp) (block checksums)
  Plex /vol1/plex0 (online, normal, active)
    RAID group /vol1/plex0/rg0 (normal)
      RAID Disk Device  HA  SHELF BAY CHAN Pool Type  RPM  Used (MB/blks)    Phys (MB/blks)
      dparity   0b.19   0b    1   3   FC:B   -  ATA   7200 211377/432901760  211921/434014304
      parity    0a.20   0a    1   4   FC:A   -  ATA   7200 211377/432901760  211921/434014304
      data      0b.21   0b    1   5   FC:B   -  ATA   7200 211377/432901760  211921/434014304
      data      0a.22   0a    1   6   FC:A   -  ATA   7200 211377/432901760  211921/434014304
      data      0a.23   0a    1   7   FC:A   -  ATA   7200 211377/432901760  211921/434014304
      data      0a.24   0a    1   8   FC:A   -  ATA   7200 211377/432901760  211921/434014304
      data      0b.29   0b    1   13  FC:B   -  ATA   7200 211377/432901760  211921/434014304
      data      0a.27   0a    1   11  FC:A   -  ATA   7200 211377/432901760  211921/434014304
      data      0b.25   0b    1   9   FC:B   -  ATA   7200 211377/432901760  211921/434014304
Thanks for the input!
lwei
You can check the RAID group size, expand it, then add the two disks:
>aggr status -r                                    // check for raidsize
>aggr options aggr1 raidsize 16     // set aggr1 raidsize to 16
>aggr add aggr1 2                              // add 2 disks to aggr1
Thanks,
Wei
mvetteplex
Actually the aggr status -r does show the added drives so all added "correctly" according to what we can see, the real problem is after adding the drives the space doesn't appear, it still shows only 592 GB of space and 85% of that is used, so it appears that 4 of the drives aren't getting into the allocation pool?
lwei
Try aggr show_space an/or df -g -A to see where the space went.   -Wei
