ONTAP Hardware
Volume Move same one cluster
DhonaAgungP
Hello Guys,
Maybe somebody any experience for same this case?
Please give me step for troubleshoot.
1 ACCEPTED SOLUTION
paul_stejskal
How is performance on the source/destination node? That first one will need to finish first. The other possibility could be BRE throttling, which is expected if latency is higher.
Lastly, how much i/o is going on with that volume? It might be so busy it can't finish a cutover.
8 REPLIES 8
paul_stejskal
DhonaAgungP
Hello Paul,
after we check performance source destination node
JonathanGaudette
Run
::> vol move show -instance
to see the actual "warning" state
DhonaAgungP
hello Jonathan,
Fyi
DhonaAgungP
where can i check snapshot capacity in node aggr_SASInternal
paul_stejskal
There may be room on disks but it could be reserved. Why are you moving to an already full aggregate? ONTAP won't perform well with being full.
DhonaAgungP
because i do volume move for replace node/aggr_SAS1800G_1. If I provide allocations in Aggr_SASInternal, the running process will continue?
paul_stejskal
That or free space up. If you're upgrading nodes the account team/Professional Services should be able to fix that.
